Forums >> Revit Building >> Technical Support >> about the uniformat codes
Tue, Jan 27, 2009 at 11:30:30 AM | about the uniformat codes
ASPARUH
Hi Revit users,I'm wondering is there any directory to download a uniformatclassifications.txt file according to the local requirments and obviously language and to overwrighte the default one... I am working in Québec and I do need the above mentioned file according to the provincial one. Ther're some differences in the numbers except the language. Apreciate any helpThanks
Tue, Jan 27, 2009 at 3:41:31 PM | about the uniformat codes
jarosa
jarosa Avatar
4 Stars: 5 Votes
Asparuh,
Is this what you are looking for?
http://www.csinet.org/s_csi/sec.asp?TRACKID=&CID=1379&DID=11342
HTH, John
Wed, Jan 28, 2009 at 6:17:09 AM | about the uniformat codes
ASPARUH
Thanks , John,
Sorry, I am looking for a .txt file. It is origially located into the instalation directory of Revit. But it contains the US codes in english. I do find bad practice to modify that file by adding codes in ddifferent language /in my case in french/.
You may call me lazy, but it is a question of a long typing. That's why I am looking for a download. It must be available. If Autodesk supplies Revit with the full list of the US uniformat codes by default, there suppose to be a replacement possibility according to the local norms.
Thanks
Uniformat Assembly Codes: Revising
Tue, Oct 7, 2008 at 3:52:19 PM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:11 AM
help scheduling rooms with assembly codes
Thu, Jun 6, 2013 at 11:02:19 AM
Omniclass & UniFormat
Thu, Oct 27, 2011 at 10:44:55 AM
Creating a Schedule showing all Assembly Codes
Tue, May 17, 2005 at 2:48:23 PM
Page generation time: 4.6875
