Forums >> General Discussion >> Revit Project Management >> Adding a Flip Control
Tue, Jan 27, 2009 at 11:29:26 AM | Adding a Flip Control
sloman
Can anyone tell me if it is possible to add a flip control to a generic annotation family?  We are trying to create a room occupancy tag for our fire safety plan which have arrows showing the dirction of travel out of the room.  We would like to create one tag and then be able to apply a couple flip controls so that we can change each tags direction, much like you do with doors.  I've noticed that the flip control is available in generic model tags but not annotation tags, but then it is somehow applied to the section tag and I can't figure out how they did that.  Any insight would be much appreciated!
Thanks!
Tue, Jan 27, 2009 at 11:52:22 AM | Adding a Flip Control
When you edit a family, the options available to you are there... as you can see, there is no flipper.  But, you can add parameters to control visibility for line elements (arrowheads at each end).
Tue, Jan 27, 2009 at 12:02:45 PM | Adding a Flip Control
sloman
I was afraid this was the case.  I guess I just thought that it would be silly of Revit to not have this option available in ally families.  It would be so much easier and useful if that was the case.  But why would they want to make anything easier or more useful...I guess that would be totally silly.
Mon, Dec 5, 2011 at 5:12:51 AM | Adding a Flip Control
horicolonoma
I opened a simple door family and I copy/pasted the flip controls...not very clean but it seemed to work
Flip Control
Thu, Aug 11, 2005 at 7:11:42 PM
Flip Control
Wed, Mar 10, 2010 at 9:22:53 AM
flip control
Thu, May 31, 2007 at 5:13:55 PM
flip control only door panel & not frame/trim revit 2015
Mon, Apr 27, 2015 at 10:19:19 AM
Flip Control on Profiles
Mon, Jul 9, 2018 at 9:25:14 PM
Page generation time: 0.1478
