Forums >> Revit Structure >> Technical Support >> Draw order of Linked Revit Files
Tue, Jan 27, 2009 at 7:13:32 AM | Draw order of Linked Revit Files
Steel2Steel
When i link the architects Revit File to my file, his drawing is showing up ontop of my drawing which is covering up my walls and other items.  Very annoying!!  Please help me this is driving me nuts!  PS  It is not a DWG link so linking to current view doesn't work in this case.
Thanks in advance
David
Tue, Feb 24, 2009 at 4:17:51 PM | Draw order of Linked Revit Files
iwong
Hi.  I am having the same problem now.  Did you ever find a solution?
Wed, Feb 25, 2009 at 6:49:04 AM | Draw order of Linked Revit Files
Steel2Steel
iwong,
under V/G you have to select a custom set up for the visibility settings for the linked revit file.  Then under model graphics and annotations (you need to make sure you click the box that says "show categories from all disciplines" select all and click the transparent box beside the halftone column.  This was the only way i could figure out how to get this to work out.  Let me know how this works.
Wed, Feb 25, 2009 at 10:06:44 AM | Draw order of Linked Revit Files
iwong
Yes, that seems to be the general consensus as the only work-around right now.
Wed, Feb 25, 2009 at 10:06:57 AM | Draw order of Linked Revit Files
iwong
Thank you!
Draw order of linked DWGs
Thu, Jun 21, 2007 at 9:14:00 AM
draw order
Wed, Aug 20, 2008 at 8:26:33 AM
draw order in revit 2010
Tue, Sep 23, 2014 at 1:24:31 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Page generation time: 1.6266
