Forums >> Revit Building >> Technical Support >> Detail Group within a group
Mon, Jan 26, 2009 at 9:51:11 PM | Detail Group within a group
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
Hi guys,
I've been using groups for a first time as I'm working on Aged Care project which has a lot of same bedroom layouts and groups come quite handy (similar to x refs in AutoCAD). I have created a group which comprises of 2 units with bathrooms and within that group I have created detail group which includes fixtures within these bathrooms (disable compliant fixtures-shower, basin and wc). Unfortunately I have to import 2D fixtures from AutoCAD library as I do not have those fixtures in my revit families. Everything was ok until I added concrete slab floor. Now my fixtures are not visible any more. If I hide slab floor fixtures are visible again. I tried to set floor slab 2mm under floor level but fixtures are not visible. What can cause this problem? And I would appreciate if anyone can send me these fixtures (must  comply with Australian Standards). I have attached floor plan with slab on (fixtures not visible) and with hidden slab element.
Thanks
Mon, Jan 26, 2009 at 10:12:35 PM | Detail Group within a group
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
I've just found another problem. When I hide slab element fixtures are visible, but in a print preview they are not visible, so disregard no slab attachment as you won't see any fixtures.
Tue, Jan 27, 2009 at 12:05:43 AM | Detail Group within a group
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
I found out what the problem was. I had to ungroup detail group and then place every fixture import in foreground as they were all in background. After that I placed detail group back into model group.  Attached is the result I was after.
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ]
Wed, Nov 23, 2016 at 3:27:29 PM
15
Detail Group Partial Visibility
Fri, Jul 15, 2016 at 10:37:44 AM
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Parameter in a Detail Group
Tue, Aug 29, 2006 at 12:26:52 PM
Converting Model Group to Link
Sun, Oct 23, 2016 at 4:58:40 PM
Page generation time: 0.1985
