19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Riser height change from default
15 Posts No Rating |
I'm using MEP 2009 and am adding stairs in a residential project. By default, the program calculates for a maximum riser of 7" which is perfect for commerical but can be increased for residential. Can I change the default of 7" or manipualte another way? thanks! Suzque
Create a new stair type duplicating the stair type you want then modify your stairs "Type" parameter for the maximum riser height...
Thanks WWHub - wished I would of thought of that! Much appreciated! :-)
default sill height |
Wed, Feb 23, 2005 at 5:26:13 PM
custom riser height for staircase |
Wed, Mar 24, 2010 at 12:08:35 AM
Custom Stair Riser Height |
Wed, May 27, 2009 at 10:00:38 AM
Setting Window Head Height |
Fri, Feb 24, 2017 at 12:16:49 AM
14
Riser profile? |
Mon, Nov 10, 2008 at 4:16:37 PM
