Forums >> Community >> Newbies >> Revit schedule formula
Mon, Jan 26, 2009 at 1:30:38 PM | Revit schedule formula
Linibel
Hi, I'm a new user, just learning and can't seem to find info on how add a simple addition formula in a schedule. I've asked my instructors and they don't know. Can anyone help me?
Mon, Jan 26, 2009 at 3:05:31 PM | Revit schedule formula
REVIT's Help there are several usefult topics:
Valid Formula Syntax and Abbreviations
Selecting Fields for a Schedule - In this topic - create a field whose value is calculated from a formula click Calculated Value. Enter a name for the field, set its type, and enter the formula for it using existing fields in the schedule.
For example, if you want to calculate an occupancy load based on the area of a room, you could add a custom field called Occupancy Load that is calculated from the Area field. Formulas support the same mathematical functions as in the Family Editor. For more information on creating formulas, see Using Formulas for Numerical Parameters.
Adding Column Totals to a Schedule
Adding Grand Totals to a Schedule
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:07 AM
Adding Dots to the Door Schedule
Fri, Dec 2, 2011 at 5:41:20 PM
Schedule with formula. Yes/no --> Show
Tue, Dec 23, 2014 at 7:34:00 AM
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:51 AM
Schedule Parameter formula not showing up [ 1 2 ]
Thu, Oct 28, 2010 at 4:33:57 PM
23
Page generation time: 2.1547
