Forums >> Revit Building >> Technical Support >> Rotating Objects in Elevation/Section
Mon, Jan 26, 2009 at 11:57:34 AM | Rotating Objects in Elevation/Section
emmettking
I am working in Revit Archtitecture 2009.
I am unable to rotate an object in elevtaion.  I am trying to use a family as a brace but it will not rotate in elevation or section.  How do you get something to rotate?  Also I have not been able to add an angle parameter to the famiyl to adjust the angle of the brace eihter.  How is any of this done, please help.
 Thank you,
Mon, Jan 26, 2009 at 12:37:19 PM | Rotating Objects in Elevation/Section
4 Stars: 205 Votes
Depend the object/family how it created, there are some obj./families they are attached to floor, ceiling, walls, whatever, and don't allowd the "rotation just like that", the best way is in fact create a ref. line and a parameter with angle in the family to control that, if you can't do that there is something wrong with that family.....
Mon, Jan 26, 2009 at 1:29:27 PM | Rotating Objects in Elevation/Section
emmettking
Tried making a parameter for the angle but the ref plane is the item that rotates in relation to my extrusion when the angle changes and not the extrusion.  I need to get the extrusion to rotate.
I am attaching the family i created.  It is a generic based family.
Mon, Jan 26, 2009 at 1:38:39 PM | Rotating Objects in Elevation/Section
tim123
4 Stars: 19 Votes
To just rotate it in elevation you may just need to edit the component and unlock it to rotate it.  With regard to a parameter, use a reference line rather than a reference plane.  Attach your component to the reference line and give the line an angle parameter.
Mon, Jan 26, 2009 at 2:27:41 PM | Rotating Objects in Elevation/Section
emmettking
I made the ref line and added an angular paramer to it.  This works, i can get the line to adjust its angle by opening the family editor and changing the value of the angle.  Once i attach my extrusion to the line by moving and locking or aligning and locking the extrusion ot the ref. line, i get an error message about not meeting the constraints.
Tue, Jan 27, 2009 at 5:00:05 AM | Rotating Objects in Elevation/Section
tim123
4 Stars: 19 Votes
You need to align and lock it in edit mode - I have created one for you with parameters for length, depth and height.   You will need to change the units to imperial and set in material parameters if required.
Tue, Jan 27, 2009 at 8:17:15 AM | Rotating Objects in Elevation/Section
emmettking
thanks for the help.  and thanks for the infomration on family building.
Rotaring Car in Elevation/Section
Tue, Oct 30, 2012 at 10:18:23 PM
viewports & section tags
Mon, Aug 8, 2005 at 10:20:31 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Families in elevtion or Section, Can it be done?
Fri, Sep 26, 2008 at 12:19:51 PM
Rotating Elevation markers accuratly
Sun, Sep 28, 2014 at 5:01:46 PM
Page generation time: 7.7188
