10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Beam system, cant offset?
3 Posts No Rating |
Hello, ive just started using revit last week so very very new to this and well i've made a beam system but cant seem to change the "start level offset/ End level offset" as it seems to be grayed out in element properties, is there a way to get around this or will i have to do it the slow way and do every beam on its own? as i would like to lower the beams by -183 but cant seem to chane it. will post screenshot if this makes sense also im using Revit structure 2009, not sure if that matters? thanks for any help/tips! Tom.
3 Posts No Rating |
will post screenshot if this doesn't makes sense***
3 Posts No Rating |
15 Posts No Rating |
try just checking the 3D box. if it doesn't do what you want then you have to unpin every beam/joist and change it to the elevation you want. if you pin them again i believe it wiil go back to the previous elevation. waht i've done is unpin them and rigth click and click on detach from plane and that has worked for me. hope this helps
First beam offset in beam system |
Mon, Aug 23, 2010 at 12:24:13 PM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Structure Beam System Wishlist |
Thu, Feb 28, 2013 at 4:18:11 PM
Beam System Tags |
Wed, Feb 27, 2013 at 12:55:27 AM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
