13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Problem with railings I created
35 Posts No Rating |
I'm completely noob to creating families. In fact, I'm reading the Revit's user guides and trying to do the tutorials witht he trianing files. As I could create a normal baluster and used it in a project, I thought it would be difficult a panel. I used the file Metric Baluster Panel.rfa to create what I did. I guess that one is the correct. So I started sketching the model (panels) and then I imported the family and used it. But you can see what happened (problem). Then I thought It would be fixed If I rotated the model (panels 2). But no! Any ideas what I'm doing wrong? Thanks a lot! (Using RAC0
What you create in "Alzado - Front" it's what you must create in "Alzado - Left", that's the right view...
thank you, Typhoon Now the panel are in the right position. But then I had another problem, as you can see in the first image. But then at the end I realized that making a raling is just like creating a wall and taking it into account, I could eventually create what I (mor eor less) wanted.
Don't create those Top and Bottom "Brown Elements" in the Family of Baluster, because you can create that like a "Rail", create a "Metric Profile Family" with that shape you want and apply in the rails that profile...
My railings doesn't go with my stairs |
Mon, Dec 2, 2013 at 11:45:03 AM
13
Problems attaching railings to stairs |
Mon, Dec 2, 2013 at 10:49:14 AM
Frenc h railings |
Wed, Feb 18, 2009 at 2:51:56 PM
11
RAILINGS RAILINGS????? |
Wed, Oct 1, 2008 at 3:48:49 PM
stair railings-inserting glass |
Mon, Dec 9, 2013 at 11:37:40 AM
