Forums >> Revit Building >> Technical Support >> Wall Openings - Changing Height
Fri, Jan 23, 2009 at 3:13:14 PM | Wall Openings - Changing Height
bcbarron
When I create a wall opening in a wall using the opening-wall tool I can set it to the precise height I need, but if I go and change the wall height, the opening changes as well.  How do I de-couple the opening height from the wall height?
Thanks,
Brent
Fri, Jan 23, 2009 at 3:25:35 PM | Wall Openings - Changing Height
4 Stars: 205 Votes
Create Dimensions and Lock them....
Tue, Jan 27, 2009 at 9:49:26 PM | Wall Openings - Changing Height
bcbarron
I tried creating dimensions and locking them but that did not work.  When you change the height of the wall by changing the elevation of the level above (the level the top of the wall is defined as) the drawing becomes overconstrained and asks that the command be canceled or the restriction removed.  Back to the original problem.
Brent
Tue, Jan 27, 2009 at 11:30:18 PM | Wall Openings - Changing Height
Sven
3.5 Stars: 3 Votes
have you tried editing the profile of the wall? i just gave that a quick try and it seemed to work - I'm not totally sure of the differences between the methods but if it ticks all the boxes for you...
Wed, Jan 28, 2009 at 8:05:26 AM | Wall Openings - Changing Height
I personally hate the opening tool.  It just doesn't work right and is very hard to adjust afterwards.  I prefer either using the Cased opening in the door family and modified not to be cased or I use the wall sketch.... but the sketch can cause you other probelms.
Wall openings not showing in linked model
Thu, Mar 15, 2018 at 2:07:06 PM
dimensioning opening height of linked file
Mon, Oct 6, 2014 at 9:49:46 AM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
scheduling height of irregular curtain wall panels
Sun, Mar 11, 2012 at 12:08:00 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Page generation time: 0.8861
