Forums >> Revit Building >> Technical Support >> line style line weights
Fri, Jan 23, 2009 at 10:41:31 AM | line style line weights
rquist
under "line styles"  "line weights" the main header called "lines"  has a line weight designation options just like all the subcategory lines.
haven't noticed a difference by changing the lineweight option from the default "1".  does it do anything??
Fri, Jan 23, 2009 at 11:46:41 AM | line style line weights
tim123
4 Stars: 19 Votes
You change that linetype here - see image.
Fri, Jan 23, 2009 at 2:51:34 PM | line style line weights
rquist
I'm just wondering if changing the line weight option for the main header "lines" has any practical meaning.
I changed it to something other than "1" but it seemed ineffectual to the line subcategories. Is there any practicality?
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Detail Lines Follow Model Line Weights Problem
Fri, Sep 9, 2011 at 9:55:51 AM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Any Suggestions For Line wt Table set up and Line Style Names
Thu, Jun 5, 2008 at 7:01:45 AM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:55 PM
Page generation time: 0.6689
