Forums >> Revit Building >> Technical Support >> Bar joist web
Thu, Jan 22, 2009 at 3:26:59 PM | Bar joist web
robertsheeley
4 Stars: 1 Votes
Revit 09'
When rendering I can not get the webs of my bar joists to render?
Any Ideas??
Sat, Jan 24, 2009 at 5:43:53 AM | Bar joist web
4 Stars: 205 Votes
Don't figure, can you please post some images to look what are you talking about?
Sat, Jan 24, 2009 at 10:03:41 AM | Bar joist web
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi robertsheeley, if I understand you, it means that you can't render 'cause you don't have the rendering dialog available on your design bar?, did you downlaod your Revit from Autodesk site????....
Tue, Jan 27, 2009 at 8:09:32 AM | Bar joist web
robertsheeley
4 Stars: 1 Votes
Erland, thanks for trying to help but im not sure where you got your response from? Maybe a different thread.
Typhoon, I figured it out. I did not have my visual settings correct. Thank you
Joist-modify-Can't make type K-Series Bar Joist-Angle Web : 22K6
Thu, May 22, 2008 at 9:48:50 AM
can't Make Type Joist error
Sat, Jun 28, 2014 at 8:00:53 PM
Parametric Open Web Joist Family
Wed, Oct 24, 2012 at 3:46:30 PM
open web steel joist
Wed, Sep 26, 2012 at 3:09:27 PM
bar joist seat depths
Mon, Nov 21, 2011 at 2:49:44 PM
Page generation time: 1.1531
