Forums >> Revit Systems >> Technical Support >> Pipe Sizes
Thu, Jan 22, 2009 at 2:45:15 PM | Pipe Sizes
bjdavis
I am trying to draw a 3/4" pipe. The drop down list does not show it butit is in the sizing table under Mechanical Settings. If you type in .75 it jumps up to one inch. ANy ideas on how to get 3/4" pipe available to draw. When autosizing 3/4" pipe is generated. We are using Revit 2009.
Thanks,
Brian
Thu, Jan 22, 2009 at 5:56:11 PM | Pipe Sizes
Mattman2248
Mattman2248 Avatar
Brian,
We had this problem and found that if you go into your settings--> project units, change the Discipline to piping and click on the pipe zize under format the Units were in fractional inches, and the rounding was to the nearest 1/2", if you change this to nearest 1/4" the drop down for pipe sizes will then show 3/4" pipe and sizes in the 1/4" range.
Matt
Revit was once a 5 letter swear word for me....
Calculating Pipe Sizes
Thu, Jan 13, 2011 at 4:30:40 PM
Revit 2012 MEP pipe sizes
Tue, Mar 6, 2012 at 2:13:57 PM
Revit MEP Custom User Pipe Sizes Not Available When Drawing Pipes
Sun, Dec 18, 2016 at 8:51:17 PM
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug?
Fri, May 18, 2012 at 10:04:27 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Page generation time: 0.0571
