17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Split face boundaries - visibilty control
1 Posts No Rating |
Using Revit 2009. I am using split faces to represent patterned areas on precast concrete wall panels - which is all very well until I need to change the appearance of the split face boundary. Using the linework tool - besides being tedious as I can only select the lines individually (tab does not select all connected lines) - works until I try to make the boundary lines invisible. Once 1 bounday line is changed to invisible, the applied finish also becomes invisible while the remaining boundary lines stay visible. What controls the appearance of split face boundaries and is there a quick way of controlling this? I can change all the boundary lines (individually) to a light gray to become indistinguishable from the pattern representation at the required scales.
Split Face boundary graphic control, Revit 2017 LT |
Wed, Nov 15, 2017 at 5:24:20 PM
editing split face boundaries |
Wed, Jun 4, 2008 at 9:43:18 AM
12
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:11 PM
SPLIT FACE BLOCK |
Tue, Jul 18, 2006 at 10:41:24 AM
Split face on floor? |
Wed, Nov 18, 2015 at 1:16:28 PM
