11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Most Bizarre Revit Problem EVER
Wed, Jan 21, 2009 at 12:31:56 PM | Most Bizarre Revit Problem EVER
NancyHKA
You might think I'm exaggerating, but this is by far the weirdest thing I've ever seen in Revit.  I noticed yesterday that in one of the floor plan views of our project, there is what appears to be two giant concentric circles infilled with a hatch.  On closer inspection, the circles are walls.  The walls are both walls that are part of the model, but in other plan views and in the 3D view of the project, the walls appear only as arcs, as they ought to be.  So it's only this one particular view (and its dependent views) that show the problem.  I could probably solve the problem by just deleting the offending walls and re-drawing them, but that would involve a lot of work at this point in the project.  Plus I am totally baffled and would like to get to the bottom of this.  Please help!  I've attached a lot of pictures so you can see what I'm talking about.
P.S. Everyone on the team denies that they had any role in the appearance of the mysterious giant circle, so I'm thinking it's stricly a Revit problem.
P.P.S.  More info re: the hatch: the hatch can't be selected, but it turns red when you have one of the walls selected and you pan in the view.
51519_Untitled-1.jpg51519_Untitled-2.jpg51519_Untitled-3.jpg51519_Untitled-4.jpg51519_Untitled-5.jpg
Wed, Jan 21, 2009 at 12:43:18 PM | Most Bizarre Revit Problem EVER
I doubt very much that this is a Revit problem.
Questions:
  1. Is this a regular wall or wall by face or something else that is unique?
  2. Does the wall have a sketch?  _ Don't know how it can since it is a circle.
  3. Did you try splitting the wall and deleting the unwanted part?
  4. Is the wall grouped in any way?
Wed, Jan 21, 2009 at 12:59:05 PM | Most Bizarre Revit Problem EVER
NancyHKA
1.  Nope.  Both walls are just normal, curved walls.  (And, weirdly, they look just fine in other views.)
2. nope
3. Tried this, but no luck.  Revit won't let me select the part of the wall to the left of the blue dot.  (See attached picture.)  And if I try to split the main wall, revit keeps the crazy lines with the biggest part of the wall.
4. nope
I've attached a close-up of the end of one of the wonky walls.  Looks like only a few of the layers go all the way around.
Wed, Jan 21, 2009 at 1:05:00 PM | Most Bizarre Revit Problem EVER
KingRevit
4 Stars: 12 Votes
this isn't weied
someone on your team just made a mistake it happens to all of us, maybe they are scarred of you and don't want to admit making the mistake
Wed, Jan 21, 2009 at 1:10:14 PM | Most Bizarre Revit Problem EVER
NancyHKA
Funny, but no - I trust my team members, and am pretty sure they're telling me the truth when they say they had nothing to do with it.
Wed, Jan 21, 2009 at 1:29:06 PM | Most Bizarre Revit Problem EVER
coreed
coreed Avatar
4 Stars: 16 Votes
trying changing the wall type to generic wall type and then change it back to the correct wall type.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 21, 2009 at 4:22:13 PM | Most Bizarre Revit Problem EVER
NancyHKA
So I figured out what the problem was...I deleted the plan regions on both of the walls (you see one of them outlined in green at the right of the last image I uploaded), and, miraculously, the weird walls returned to normal.  I re-drew the plan regions and everything looks good...for now.  Thanks everyone for your replies, really appreciate it.
Thu, Jan 22, 2009 at 11:22:08 AM | Most Bizarre Revit Problem EVER
coreed
coreed Avatar
4 Stars: 16 Votes
what are you using the plan regions for? just curious.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jan 22, 2009 at 11:28:33 AM | Most Bizarre Revit Problem EVER
NancyHKA
to display some windows that are above the cut plane (7'-0" above the floor).
Thu, Jan 22, 2009 at 11:43:49 AM | Most Bizarre Revit Problem EVER
NancyHKA
to clarify, 7' is the height of the windows.  cut plane is at 4'-0".
Arc wall spawns bizarre hatched circle wall visible in plan view only
Sat, May 16, 2015 at 3:54:11 PM
Bizarre Printing
Thu, Jan 19, 2006 at 12:24:46 PM
Rotation Problem
Fri, Mar 2, 2007 at 9:02:32 AM
Revit 2014 schedules... where did the Show button go?
Mon, Dec 16, 2013 at 2:18:43 PM
weird yellow render RAC2009
Tue, Jan 6, 2009 at 10:34:22 AM
Page generation time: 6.8281
