37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to Print Large Door Schedules Revit 2009
Wed, Jan 21, 2009 at 11:32:11 AM | How to Print Large Door Schedules Revit 2009
grwilliams
REVIT 2009
Typically, our door schedules don't fit on one full size (24x36) sheet and when they are placed on a sheet, the the remaining portion of the door schedule that doesn't fit causes Revit to print everything beyond the border of the sheet.  How do you get the portion of the door schedule that doesn't fit on the sheet to hide so that it doesn't affect the printing of the sheet?
Thanks in advance for any help or suggestions.
Gregory Williams, AIA, LEED AP
Wed, Jan 21, 2009 at 11:39:54 AM | How to Print Large Door Schedules Revit 2009
tim123
4 Stars: 19 Votes
Duplicate your door schedule and use a filter to separate the doors by floors or door numbers or other convenient parameter.
Wed, Jan 21, 2009 at 11:45:00 AM | How to Print Large Door Schedules Revit 2009
coreed
coreed Avatar
4 Stars: 16 Votes
also remember you can split your schedules in parts if that option will help
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 21, 2009 at 12:06:06 PM | How to Print Large Door Schedules Revit 2009
grwilliams
I understand that the schedule can be split.  And we also understand the use of filtering.  However the real issue is comes with a door schdule with multiple filtering needs.  Because of the door naming convention, we've already used 3 of the filtering fields.  For example, we have Corridor doors that occur on all floors (C1000), Headhouse Doors that occur on only one floor (H1xxx), standard doors (1000,2000,3000, & 4000),and Research Doors (R1000).  We have used these designations so that these would group the way we want them to on the schedule.
Is there anyway to add additional filtering rows?  If so then maybe this would work for removing the portion of the schedule we don't want to see.
Thanks in advance for any response.
Wed, Jan 21, 2009 at 12:11:07 PM | How to Print Large Door Schedules Revit 2009
coreed
coreed Avatar
4 Stars: 16 Votes
looks like your going to have to add some additional shared parameters to your door families that you can use to filter your schedules by.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 21, 2009 at 12:28:45 PM | How to Print Large Door Schedules Revit 2009
Instead of filtering for the door number - just use 1 shared parameter to your doors to filter "CONTAINS".  Call it - Schedule -  Then put a value ... 1-2-3 or A-B-C whatever to filter for.  Doors to show in all schedules could have all values A-B-C - otherwise just the schedule they will show in.
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Door Schedules - Revisions
Fri, Nov 12, 2010 at 4:10:09 PM
Schedule Line Shading - Revit 2009
Sat, Oct 2, 2010 at 8:46:19 AM
Schedules: Ie Door schedules!
Fri, Jul 11, 2014 at 2:58:22 PM
schedules show up on sheets too large?
Fri, Apr 21, 2006 at 6:09:20 PM
Page generation time: 1.8678
