19 Users Online (17 Members):
Forums >> Revit Systems >> Tips & Tricks >> Adding New Mullions to your Mullion Tab Options
Not so sure how well I can explain this in a sentence or two- but when you need to have a new mullion in your drop down menu for your Mullion Tab in Modeling. I found this little trick today. In the family categories in the drop down menu in the left hand corner- there's a section in families for Curtain Wall Mullions. Click the plus box and it will show you what Revit already has in it's data base. This is not an option to "load" into a properties box- Right click one of these mullions, and chose New Type. This will then bring up the properties box for that type of mullion - say a L shape corner mullion- Here is where you can change the mullion properties to your personal needs and then click okay. This will then bring up the different types of mullions in your MULLION TAB when you are setting up your curtain walls. This only took me 4 hours to figure out!!! So hope it helps anyone in need!
Ashupe, well, if you did the question here you save the "4 Hours"....
I didn't feel like being too much of a pest considering there is about 4 threads with the exact same question and issue- and no answers were linked to theirs!!!
I think it's G R E A T that ashupe took the time to post this as a tip so that others could find this when they search the forums. I wish others would do the same. Thank you ashupe.
LOL, yeah WWHUB, there are guys who don't spend 1 minute to search in the HELP menu or take a look in the tutorials, well, i think you are right....
1 Posts No Rating |
thanks for this helful post. One more question - how do we insert the mullion into a preexisitng curtain wall? I tried to put it in but a wierd cros with arrows on each end came up not letting me insert them.
Not 100% sure here, but I'd select all the mullions I want to replace in that curtain wall, then using type selector, choose the appropriate mullion type... If you change it in the curtain wall properties, I believe it doesn't do anything until you create a new curtain wall of that type, then it will populate with new mullions. But I'm suspect on this because I haven't dealt with curtain wall since 2009!
Trent Best
Best Systems
the.tabest@gmail.com |
Mullion will not load |
Tue, Jul 22, 2008 at 8:20:07 AM
cleanup horizontal mullion at corner mullions, again.... |
Wed, Jan 8, 2014 at 11:14:49 AM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
Mullions within in panel family |
Mon, Jun 12, 2017 at 2:32:28 PM
curtain wall mullion family |
Tue, Jun 10, 2014 at 9:23:36 AM
