28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Custom Elevation Tags
23 Posts No Rating |
How can I use my own elevation tags with elevation number and drawing number instead of the standard elevation symbol?
Does anyone actually show elevation symbols like the Revit standard?
Many thanks in advance.
This has been a request for quite some time. But as elevations are system tools they cannot be replaced with loaded families ala section markers. You just get a choice between circles or boxes.
This is now possible. Go to settings - view tags - elevations and now you can duplicate and edit elevation tags.
1 Posts No Rating |
So if you can only choose b/w circle and square on the millwork elevation tag, how do you get rid of the text outside the circle? if you erase the txt in the view name box in the elements properties window. it says, "view name box is empty" and it won't let you delete the txt in floor plan view.
1 Posts No Rating |
This is now possible. Go to settings - view tags - elevations and now you can duplicate and edit elevation tags. You can Create your own symbol and assign that.
Elevation Tags Style |
Tue, Nov 13, 2007 at 4:25:23 AM
Creating custom tags & custom categories in Schedules function |
Thu, May 26, 2005 at 6:57:27 PM
Creating custom tags & custom categories in Schdules function |
Thu, May 26, 2005 at 6:42:45 PM
Custom Elevation Symbol is upside down sometimes |
Tue, Apr 12, 2011 at 11:10:28 AM
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
