26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Linked rvt into another rvt
it doesnt seem to be possible to have a file with linked in rvt files, and then link this file into and other rvt file, or is there a way? Kind regards, D
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
I am working with a nested linked file right now so it is possible. I don't know what you are doing wrong. Did you verify the paths for the nested link is correct?
The model you are linking has other models linked into it. These links wil not be visible in this file, this is what revit tells me,
peace is the path."
Mahatma Gandhi.
Check out your H E L P - Here is part of it "Linking Revit Models that Contain Links When you import a Revit model that contains a linked Revit model, links become nested. You can show (or hide) nested linked models in the host model. By default, nested linked models are not visible in the host model."
Got it to work  TNX!! WWHub
peace is the path."
Mahatma Gandhi.
Tagging rooms in linked RVT files |
Wed, Dec 13, 2006 at 1:48:03 PM
linked revit structure.rvt |
Fri, Jun 21, 2013 at 11:18:52 AM
Deleting Linked RVT Categories |
Fri, Feb 3, 2006 at 9:40:29 AM
RTE vs RVT |
Thu, Sep 26, 2019 at 9:21:04 PM
save as from template to rvt |
Wed, Feb 15, 2012 at 6:31:16 PM
