Forums >> Revit Systems >> Technical Support >> Walls with varying exterior material thicknesses
Mon, Jan 19, 2009 at 7:57:56 PM | Walls with varying exterior material thicknesses
apayne
Can anyone enlighten me on how to get varying material thickness within a one storey portion of wall, for example brick bottom 3 ft, concrete coping and wood siding above with the materials NOT aligning (stuck) to the outside face of the brick?  I have tried duplicating an existing wall type but the finishes always stick to the outside face of the brick.
I am very new to revit so it might be something comletely obvious to everyone else.
Thanks,
Andrew
Tue, Jan 20, 2009 at 2:47:09 PM | Walls with varying exterior material thicknesses
4 Stars: 205 Votes
I'm not quite sure about what really do you need but, Create a Profile Family with the shape and height you want (3 ft), then load to project and use "Modeling>Host Sweep>Wall Sweep", go to properties and change the profile you just create, give the material you want then apply to wall whatever you want...
Tue, Jan 20, 2009 at 3:10:35 PM | Walls with varying exterior material thicknesses
No to Typhoon suggestion ... just use a stacked wall set up like you want.  There should be one you can modify in your model.
Wed, Jan 21, 2009 at 7:25:52 PM | Walls with varying exterior material thicknesses
apayne
so either i create two different walls on top of one another or i use one of the preloaded wall famillies, duplicate and edit it.  I understand the basics of editing the wall, but I can't get the face in the section preview to be in or out from the portion above or below it, the only thing that seems to do that is the reveals and sweeps.  Do I have to use them for the entire portion of exterior wall finish that i want set back?
It is a pretty standard detail so I fail to see why Revit wouldn't have one already loaded and all you have to do is change the finishes and heights to what you want.
This is where i start to loose my faith in revit as a better program, but I know I am just frustrated!
Thu, Jan 22, 2009 at 12:58:40 AM | Walls with varying exterior material thicknesses
erland73
erland73 Avatar
4.5 Stars: 85 Votes
HHeyyy...calm down apayne!!!!...All is posible in Revit but with a little bit of patience. I can't still understand what exactly do you need but I'm trying to read your mind. I don't know if you want something like the image attached (i tried to exaggerate the materials), but it'd be better if you upload a kind of picture or draw of the wall you want in order to help you.
Thu, Jan 22, 2009 at 4:36:15 AM | Walls with varying exterior material thicknesses
4 Stars: 205 Votes
Yeah man, and Image "Paint" more than 1000 words...
Thu, Jan 22, 2009 at 5:38:20 AM | Walls with varying exterior material thicknesses
Adnanito
3 Stars: 2 Votes
Stacked walls allow you to create a single wall entity composed of different wall typesstacked vertically on top of each other. The wall types used in a stacked wall need to be typesalready defined in your project.Create the individual wall types u want to use in stacked wall, then select the wall tool go to its type properties , choose Stacked wall from family dropdown-menu and duplicate existent  type and edit the structure parameter…the resulting dialog looks like the ordinary wall edit assembly, but here u don't add/remove layers..instead u deal with walls stacked over each other if u noted .u can create whatever composed walls u wish specially the offset problem u're facin..Just trying to explain what Hub &Erland told u .
Moh_Adnan_Alj
Varying roof thickness by slope change
Fri, Sep 2, 2016 at 1:25:38 PM
The same (one wall) to have varying thickness in its width dimension not height?
Thu, Mar 1, 2012 at 10:17:43 AM
varying slab thicknesses
Thu, Sep 27, 2007 at 2:12:31 PM
Wall join at ends of two walls with different thicknesses
Thu, Jul 17, 2014 at 1:21:31 PM
Spot Elevations on curved walls with varying height
Tue, May 3, 2011 at 5:26:46 AM
Page generation time: 1.2996
