Forums >> Revit Building >> Technical Support >> Giving topography thickness when rendering
Mon, Jan 19, 2009 at 5:55:53 PM | Giving topography thickness when rendering
wil9000
Hi,
I form the topography to the boundaries on a sloping site. when i want to render a 3d elevation  the topography comes up as a single thickness. my question is does anyone know or is there a way to give topography a thickness when rendering, basically to hide all the foundations etc below ground?
thanks in advance
Will
Tue, Jan 20, 2009 at 3:13:33 PM | Giving topography thickness when rendering
4 Stars: 205 Votes
Something like this??? go to Settings>Site Settings>Elevation of poche base....
Tue, Jan 20, 2009 at 3:36:02 PM | Giving topography thickness when rendering
wil9000
Thanks for the reply, unfortunately not what i was after, if you have a look at the attached i want to fill the void beneath the line of topography so that you will not see the reatining walls footings etc, just wanted to know if i was possible when rendering
Tue, Jan 20, 2009 at 7:16:52 PM | Giving topography thickness when rendering
puzzle
4 Stars: 10 Votes
turn on the section box in the 3d view and move it around to suit. you wiil find the section box in the view properties.
Macca
Sunshine Coast
QLD Australia
Tue, Jan 20, 2009 at 8:02:32 PM | Giving topography thickness when rendering
Sven
3.5 Stars: 3 Votes
We've tried a number of options with our renderings, including some already suggested. I find we get best results when we extend the toposurface beyond that of the specific site. I then often split the surface and make the neighbouring sites a different render material so that the subject site has a little more definition. Hope this works well enough for you.
Thu, Jan 22, 2009 at 9:25:38 AM | Giving topography thickness when rendering
wil9000
Thanks for your replies, but what i am trying to achieve is like the in the attached image
Thu, Jan 22, 2009 at 9:42:06 AM | Giving topography thickness when rendering
4 Stars: 205 Votes
Made like Puzzle said, create a Section view in plan then go to your 3D view, in the view cube with the right button click in orient-by-plane, select sections> the section you create, then just adjust the image like you want, adjust also the section box, then pick in the section box and "Hide element"...
Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 7:53:01 AM
feedback on my rendering [ 1 2 ]
Wed, May 13, 2009 at 11:43:02 PM
24
Elevated sidewalk
Fri, Jan 21, 2005 at 5:30:08 AM
Distributed Rendering to Rendering Server
Thu, Jun 14, 2007 at 2:12:25 PM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 0.2186
