Forums >> Revit Building >> Technical Support >> Revit 2009 to FBX Import into MAX 9?
Mon, Jan 19, 2009 at 2:09:33 PM | Revit 2009 to FBX Import into MAX 9?
jeffrb25
HI, I just purchased MAX 9 to do some walthroughs of the Revit 2009 project and was told to use FBX as I have already maps and lights in Revit to transfer over.  Unfortunately, there is an error in importing FBX.  I read here on another post that you might not be able to import Revit 2009 into Max 9 (Honestly, whats the difference between Max 9 and Max 2009???) Any suggestions how to get my Revit to import into Max 9 with FBX as it is an option in Max 9 to import or did I mess up and not buy 2009 for importing? I guess I could do DWG if all else fails??
Thanks
Mon, Jan 19, 2009 at 3:46:34 PM | Revit 2009 to FBX Import into MAX 9?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi  jeffrb25, Revit 2009 .fbx files are only compatible with 3ds Max 2009 or 3ds Max design 2009.In fact, once I tried to do that with 3ds Max 2008 and I couldn´t, so I´d to install 3ds max 2009 on my computer.I don´t know if the one who told you that maybe confused the names (Max 9 with Max 2009)?.....
Edited on: Wed, Apr 1, 2009 at 12:27:29 PM
Tue, Jan 20, 2009 at 12:42:29 PM | Revit 2009 to FBX Import into MAX 9?
jeffrb25
I had a bad feeling about that.  Still not sure the differences betweent the MAX softwares as I am new to it.  MAX 9 has FBX import option?? What is best for rendering and walkthroughs for buildings creating in Revit?  Max 2009 or Design 2009?  What version of FBX files can 9 import?
 Thanks
Tue, Jan 20, 2009 at 1:18:49 PM | Revit 2009 to FBX Import into MAX 9?
coreed
coreed Avatar
4 Stars: 16 Votes
i think max design 2009 is a scaled down fearture version of 3ds max 2009 for those who don't need full-blown Max.
i think the rendering quality should be some what comparable?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jan 20, 2009 at 3:18:43 PM | Revit 2009 to FBX Import into MAX 9?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jeffrb25, Max 2009 and Max design 2009 are basically the same, the main difference is that 3ds Max design 2009 is "especially" for interior designers and architects. Why?, ´cause you´ll find many materials (promaterials) there, (if you use mental ray for renderings of course)......but in anyway, you can export .dwg files from Revit 2009 to 3ds Max 9 and render with whichever renderer you want (mental ray, vray, Brazil, Maxwell, etc.). Finally Max 9 can import .fbx files but not from Revit 2008 or 2009.
Tue, Jan 20, 2009 at 3:27:45 PM | Revit 2009 to FBX Import into MAX 9?
jeffrb25
Hi erland 73,  GREAT! I feel I am finally getting somewhere here, thanks for the info.  I will try to import into Max 9 a dwg file and see how it turns out.  I have done some pretty good rendering output from Revit 2009, but want to do animation with people moving, etc.  Where can I get people to move around my model in Max 9? Is there an architecture plugin for poeple, trees, entourage, etc.
Thanks again
Tue, Jan 20, 2009 at 3:46:57 PM | Revit 2009 to FBX Import into MAX 9?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jeffrb25, of course, there are many plugins for 3ds max, but usually not for free. I don´t see your e-mail in your profile, so i could send to you some models (I repeat just some models.......)
Tue, Jan 20, 2009 at 3:55:21 PM | Revit 2009 to FBX Import into MAX 9?
jeffrb25
Models would be great.  Is there an online tutorial for doing walkthroughs with people and such?
My email is jeffbarrettdesign@gmail.com
website is www.jeffbarrettdesign.com
Thanks
Tue, Jan 20, 2009 at 4:18:08 PM | Revit 2009 to FBX Import into MAX 9?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
hi jeffrb25, here some sites: http://www.3dsmaxresources.com/,  http://www.amazing3d.com/services/tutmax.html.
Ahhh, BTW, here is a site where you can download free 3d models: http://3delicious.net/.
Wed, Jan 21, 2009 at 1:12:22 PM | Revit 2009 to FBX Import into MAX 9?
KingRevit
4 Stars: 12 Votes
revit to cad, explode, then to max using import manager is the best way,
for more info about the dwg to max part log onto a max forum
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:13 PM
17
FBX import 3ds Max 64 bit
Mon, Dec 8, 2008 at 2:19:42 PM
MAX TO REVIT?
Tue, Feb 10, 2009 at 8:38:48 PM
Page generation time: 6.8880
