Forums >> Revit Building >> Technical Support >> how to transform my 3d from 3dsmax into technical drawing
Mon, Jan 19, 2009 at 12:05:39 PM | how to transform my 3d from 3dsmax into technical drawing
eduardoqf
Hi everyone!
I,ve been trying do make a section from a imported dwg file generated by 3dsmax. I can import it into revit architecture 2009, but it can´t read the section. I also tryed to make a section box and "export to cad formats", but revit exports the file as a 3d, not a 2d drawing that i need to transform my 3d from 3dsmax into technical drawing.
thanks a lot!!
Mon, Jan 19, 2009 at 1:32:51 PM | how to transform my 3d from 3dsmax into technical drawing
4 Stars: 205 Votes
Hi, "I also tryed to make a section box and "export to cad formats", but revit exports the file as a 3d, not a 2d drawing that i need to transform my 3d from 3dsmax into technical drawing." , put your section (in Revit) in one Sheet, then when you export choose that sheet, it appears in 2D....
Saving to 3dsMax?
Mon, Jul 10, 2006 at 3:03:49 PM
Do we need to revamp technical forum?
Wed, Sep 22, 2004 at 3:06:24 PM
Hide/isolate in view versus in print
Sun, Mar 22, 2009 at 3:53:37 PM
Revit to 3dsMax for GPU utilization
Fri, Dec 21, 2012 at 12:12:35 PM
revit file too heavy when importing into 3dsmax
Fri, Sep 11, 2009 at 1:13:54 PM
Page generation time: 1.2529
