Forums >> Revit Building >> Tips & Tricks >> Rendering Animations - inconsistent output resolution
Mon, Jan 19, 2009 at 10:08:14 AM | Rendering Animations - inconsistent output resolution
fredklein
I'd ordinarily render an animation in 3dsMax, but time constraints and lack of RPC support forced me to use Revit for a fairly large animation.
Quality and rendering time hasn't been an issue, but what I'm running into is if I break up a walkthrough between different computers, even with the same settings, the jpegs are coming out at different sizes.
For instance,  all the the 3D views are set at the same size, all exposure settings are matched, but the output from 2 machines on the same walkthrough produced one series of jpegs at 1037x776, and the other at 876x656...
How can I avoid this?  Is there a control feature hidden away somewhere that I can use to force a resolution?
 And a side note - Is there a way to turn off the frame numbering in the upper left corner?  Its helpful at times for organizing the stills or finding errors, but forces me to letterbox the animation in Premiere.
 CryingRevit Architecture 2009)
Mon, Jan 19, 2009 at 10:33:15 AM | Rendering Animations - inconsistent output resolution
4 Stars: 205 Votes
Are you using the same Codecs in both computers (same render walkthrough codec)???? to turn off that "Frame Numbering" you must use external programs like "VobSub" I think.....
CMYK rendering output...
Fri, Mar 14, 2008 at 6:37:51 AM
Linked DWG only printing at low resolution
Thu, Feb 19, 2009 at 2:39:53 AM
Moving shadows in animations
Thu, May 5, 2011 at 5:42:26 PM
Revit 2010 - Rendering problems??
Tue, May 24, 2011 at 11:02:20 AM
Inconsistent Pi
Sun, Mar 1, 2009 at 5:45:25 AM
Page generation time: 0.1528
