Forums >> Revit Building >> Technical Support >> Cut Pattern settings for a Coarse Shaded 3D view
Mon, Jan 19, 2009 at 9:46:26 AM | Cut Pattern settings for a Coarse Shaded 3D view
Dougie
Does anyone know where I can find the settings that control the cut pattern for a coarse shaded 3D view? Please refer to the attached image to better understand my question. As you can see the cut pattern for alla objects is a solid blue fill but I can't find this setting anywhere. Any idea?
Mon, Jan 19, 2009 at 9:53:53 AM | Cut Pattern settings for a Coarse Shaded 3D view
4 Stars: 205 Votes
If i remember it's a "Poche" material... you can change that in Materials with that name, also check in VG, right now i don't have here Revit but take a look....
Mon, Jan 19, 2009 at 10:01:50 AM | Cut Pattern settings for a Coarse Shaded 3D view
Dougie
You're correct. Thanks a lot!
Poche Walls
Mon, Jun 23, 2008 at 2:11:53 PM
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
section problem
Wed, Jun 8, 2005 at 11:06:40 PM
Cut Pattern for Curtain Panel Not Showing in Plan
Fri, Sep 5, 2014 at 6:25:57 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Page generation time: 2.0959
