Forums >> Revit Building >> Technical Support >> merging into template
Tue, Jun 7, 2005 at 4:28:13 PM | merging into template
tyar74
I'd like to merge an exiting rvt file into a template, but it will only bring it in as a block. I need to be able to edit everything once its brought in. Is there any way to "explode" the block or make it editable? Post edited on 2005-06-07 10:28:40
Wed, Jun 8, 2005 at 1:01:35 AM | RE: merging into template
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What do you mean by bring it in to a template?? If you need to edit it you will need to open the file and select all the 3D elements copy to clipboard and paste in the other file... HTH.
Merging Projects
Fri, Jun 26, 2009 at 4:53:17 PM
Merging Shared Parameters
Mon, Jun 8, 2009 at 3:08:12 PM
Merging Toposurfaces
Tue, Apr 21, 2015 at 8:07:53 AM
Beam not merging
Mon, Mar 16, 2009 at 5:57:09 AM
Toposurface Help (Merging Surfaces) Road and Curbs
Tue, Jul 29, 2014 at 8:10:48 AM
Page generation time: 0.0917
