Forums >> Revit Building >> Technical Support >> Baluster Question
Tue, Jun 7, 2005 at 3:55:28 PM | Baluster Question
quiller
quiller Avatar
2.5 Stars: 3 Votes
How do I get 2 baluster pre thread and have both connected to the thread. I can only seem to get one to connect and the other is higher, and I'm assuming it's following the angle of the stringer. Cheers, Alan
Wed, Jun 8, 2005 at 12:59:35 AM | RE: Baluster Question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Change the baluster offset to 0.
Wed, Jun 8, 2005 at 3:09:45 PM | RE: Baluster Question
quiller
quiller Avatar
2.5 Stars: 3 Votes
If it were that easy!!!!! Please check out the attached doc and let me know what you think. Alan
Wed, Jun 8, 2005 at 10:56:54 PM | RE: Baluster Question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Providing you have baluster's per tread set to 2 and there base set to host and the baluster is completely on the tread in section (not half overlapping which is why i suggested the above) then it should work no problems. I just tested it and worked a treat. HTH.
rail 1 and baluster heigth
Tue, Nov 8, 2011 at 10:40:22 AM
custom baluster with decorative piece not staying equal 2019
Thu, Jun 14, 2018 at 1:54:47 PM
Need help! Custom baluster
Mon, Apr 20, 2015 at 7:40:11 AM
Baluster Height Issue
Tue, Nov 6, 2007 at 6:37:15 PM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:53 AM
Page generation time: 0.2049
