Forums >> Revit Structure >> Technical Support >> Show block coursing on 3D views
Thu, Jan 15, 2009 at 3:29:35 PM | Show block coursing on 3D views
minfante
I am using Revit Structure 09.  On my previous project I had set something to change the display of masonry walls in 3d views.  I want to display the individual block lines on the surface.  How is that done?  I'll write it down this time.
Mon, Jan 19, 2009 at 9:48:48 PM | Show block coursing on 3D views
emgeeo
3.5 Stars: 7 Votes
Tough one.  I can't get it to work.  Try messing around with the walls material.  I can get this to work on a small scale- in-place family, but not on a system wall family.  Interesting.
Anyone else?
Bump.
Tue, Jan 20, 2009 at 9:48:39 AM | Show block coursing on 3D views
If it is a non-rendered view and if you have a model hatch assigned to your wall finish then the block will show.  Rendered views require the correct render material to be assigned to the wall finish.
Tue, Jan 20, 2009 at 1:51:34 PM | Show block coursing on 3D views
minfante
Hooray!  I got it.  My masonry wall material does have an associated block surface pattern.  It just wasn't showing up.
1. VG -> Model Categories tab
2.  Select walls (in this case).
3.  In the Projection/Surface -> Patterns, field pick Override button
4.  Check the "Visible" box in the Fill Patterns Graphic Dialog.  (it should be unchecked if there's no coursing showing up on 3D shaded views with lines)
Coursing for masonry now displays in 3D views, shading with edges detail level.
Thank you for input.
Creating Soldier Coursing Above Windows
Sat, Feb 18, 2017 at 8:55:45 AM
Material Surface and Cut Pattern accuracy
Sun, Jan 27, 2008 at 9:24:46 AM
CMU Block Modules
Sun, Sep 12, 2010 at 12:23:36 PM
Elevations - remove brick coursing
Wed, Nov 7, 2007 at 9:20:28 AM
Brick Coursing Changing to Vertical At Wall Opening
Mon, Dec 24, 2012 at 2:17:38 PM
Page generation time: 5.5972
