Forums >> Revit Building >> Technical Support >> walls slightly off axis?
Thu, Jan 15, 2009 at 3:11:56 PM | walls slightly off axis?
paulykustomz
paulykustomz Avatar
I have searched the forums and have not found a sure answer on how I can find thewalls that are "off axis" is the some sort of check I can run or a filter I can use to isolate or Identify these walls?
Thu, Jan 15, 2009 at 5:06:36 PM | walls slightly off axis?
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, go to tools-->review warnings (down the bottom)--> then you'll see "wall is slightly off axis" and all the walls that are off axis will show up in a drop down menu. Expand the menu and you'll see something like "Walls: Basic Wall...ID 12345". Just click on it and it will turn orange, but if you can't see it just click "Show" in the bottom left hand corner. Keep cycling views (click show) until it shows up if you can't see it the first time. Hope this helps =)
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Lines slightly off axis
Thu, Nov 9, 2006 at 1:36:13 PM
Axis of floor plan are slightly rotated
Thu, Jun 16, 2016 at 5:52:13 AM
"Line in Sketch is slightly off axis and may cause inaccuracies."
Thu, Jul 7, 2011 at 6:47:16 PM
Shocking Survey Data, nothing drawn to a UCS! slightly off axis errors imenent!!
Mon, Dec 10, 2012 at 10:30:08 AM
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Page generation time: 1.0872
