18 Users Online (16 Members):
Forums >> General Discussion >> Revit Project Management >> exporting to navisworks mwc file ...what units ???
19 Posts No Rating |
i am exporting my METRIC project out to run a clash detection in Navisworks. so in my Export scene as, dialog box i go to Navisworks settings and set the world units to millimeters (metric job) and ok i open the job project in naviswork change the file units and transform dialog to millimeters as well as the Global options/interface/display units to millimeters and my model is not the correct size. to get the correct size i have to export out as world units inches and change the file units and transform units to inches and keep the display units to millimeters to get the correct size. with my autocad mep model everything changes to millimeters which makes sense. so this had led me to believe that there is a problem with my metric template file, so i tested this with an out-of-the metric template file and the same thing has happened. so has anybody else found a problem exporting to navisworks using meteric units. and has anybody found a solution. kind regards
Hi, We had this problem also but we found the solution is to use feet instead of metric and dont ask why. Mick
Be brilliant,
Michael |
Revit link not exporting to navisworks |
Tue, Jul 14, 2009 at 4:47:50 AM
Revit 2018 - exporting from Revit to Navisworks, wrong format file not nwc !!! |
Thu, Mar 15, 2018 at 3:25:55 PM
Navisworks 2016 Linked files not included when exporting to NWC file format |
Wed, Apr 20, 2016 at 11:07:17 AM
Export Issue from revit to navisworks |
Thu, Apr 15, 2010 at 9:14:18 AM
Origin Issues when Exporting to Navisworks |
Fri, Jan 13, 2012 at 2:03:14 PM
