18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009: Ceiling Wall: Gypsum under
45 Posts No Rating |
Hi, I am trying to draw a ceiling. See attached Image. I think I should draw a small wall. Is there a way to get gypsum under the wall? Thanks! Math.
You can edit the wall properties to show this. Go to the wall properties and edit the structure. Click on the preview button and set the view to section view. Click on Split Region and draw a line where the gypsum will end. Click on merge regions and higlight the boundary between the vertical and horizontal gypsum. Move the gupsum layer into the core .
Ditto tim123, i would move the other gypsum layer into the core also also i would duplicate and name this wall type so that it is not mistaken to be used in a standard type wall usage HTh
Edited on: Thu, Jan 15, 2009 at 10:38:35 AM
Yeah, good point, this modification will apply to all walls of this type.
Super Thanks!
Oups! I dont really get it! I mean, I'm trying.....
Ok. Ive done it! Thanks to all!
Gypsum ceiling with vertical walls to create soffit? |
Thu, Dec 18, 2008 at 9:34:06 AM
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
Gypsum board wall |
Wed, Nov 22, 2006 at 4:17:12 PM
wall height defined by ceiling |
Thu, Aug 7, 2008 at 10:21:43 AM
Recessed Cans... Revisited |
Tue, Aug 4, 2009 at 2:39:08 PM
