Forums >> Revit Building >> Technical Support >> Wall which widens out over length
Thu, Jan 15, 2009 at 5:41:08 AM | Wall which widens out over length
RNLRNL
What is the best way to create a solid wall that has a thickness of 30cm at 1 end and 1m at the other end - ie the wall gradually becomes wider?
Thu, Jan 15, 2009 at 5:43:53 AM | Wall which widens out over length
4 Stars: 205 Votes
You can use the "Solid Extrusion or Solid Blend" to do that...
Shear Wall Length
Tue, May 24, 2011 at 5:00:45 PM
Wall Length for Wall hosted family Length
Sun, Mar 2, 2008 at 2:54:20 PM
Shear wall tag with label that reads wall length
Fri, Oct 21, 2011 at 5:57:35 PM
Storefront schedule: wall length changes
Mon, Jun 6, 2011 at 12:44:46 PM
Cannot edit wall length in Revit
Sun, Jun 4, 2017 at 1:51:08 PM
Page generation time: 4.8654
