Forums >> Revit Building >> Tips & Tricks >> Incremental Circle Tag
Wed, Jan 14, 2009 at 6:39:28 PM | Incremental Circle Tag
cadmonkeygonewild
How do I go about making a Genereic Tag that will number sequentially (same as a column bubble) as I insert into a view?  Trying to make an easy way to number parking spaces that are drawn as model lines, and want something that will number sequentially as I insert......having a brain fart!
Wed, Jan 14, 2009 at 11:53:23 PM | Incremental Circle Tag
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
Even though I would not generally recommend to apply a bunch of column grids to label parking spots, it can be done in this way! (However, you may run into problems when trying to establish unique a grid name)
Edit the properties of the Grid.
"Duplicate" your grid type and label it something like "Parking Tag" >> Within the "Graphics" parameters, turn the color of the "Line" from black to white and turn off "Symbol at End 2"
Voila... Now when you copy it will be numbering sequentially, as it should Smile
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Include Tag Symbol on Schedule ?
Wed, Sep 21, 2011 at 4:12:44 PM
Elevation Tag Mark (the circle) does not filter
Tue, Oct 16, 2012 at 1:55:49 PM
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:46 PM
Changing Size of Elevation Tag
Mon, Apr 9, 2012 at 9:40:20 AM
Elevation Tag
Mon, May 29, 2006 at 7:29:36 AM
Page generation time: 0.1513
