Forums >> Revit Building >> Technical Support >> Duplicate Views with alternate componets
Wed, Jan 14, 2009 at 6:02:57 PM | Duplicate Views with alternate componets
fpopa
Can anyone help me with a new challenge that I have?  I want to duplicate the same view (i.e. floor plan) so I can maintain the same wall configuration and other components throughout, other than I want to have one show a base plan and another show some modifications to the plan (as an alternate).... Please Help, if you know how...
Thank you,
Thu, Jan 15, 2009 at 5:16:08 AM | Duplicate Views with alternate componets
tim123
4 Stars: 19 Votes
You can duplicate the view with detailing and you will have an exact copy of hte first view.  Make the neccessary modifications.  It sounds as if you actually want to change some model components.  If this is the case, the first drawing will also be altered.  You need to use design options if this is the case.
Looking For TV Broadcast Componets
Wed, Feb 12, 2014 at 10:39:29 AM
editing componets and plan view
Mon, Sep 21, 2009 at 3:50:18 PM
Duplicate views create duplicate callout tags in referring views...
Fri, Mar 9, 2012 at 1:37:25 PM
alternate dimensions
Mon, May 24, 2010 at 1:30:15 PM
Using Revit for multi-level alternate
Tue, Apr 29, 2014 at 11:16:33 AM
Page generation time: 0.2384
