Forums >> Revit Building >> Technical Support >> Trimming multiple witness lines?
Wed, Jan 14, 2009 at 2:29:39 PM | Trimming multiple witness lines?
steveo5c
I am a new user to Revit Arch 2009 and I was wondering if it is possible to trim back multiple witness lines all at once or if you have to trim each witness line back individually? I am sure that since I am new to this platform that I am just overlooking something but I can only seem to do it witness line by witnesss line which will be quite a pain on large projects.
Please let me know.
Steve
Wed, Jan 14, 2009 at 2:34:37 PM | Trimming multiple witness lines?
Witness lines can not be trimmed but they can be individually moved by grabbing the blue dot.
Look at you dimension settings.  The witness line gap is set there to control them when they are placed.
Wed, Jan 14, 2009 at 2:35:48 PM | Trimming multiple witness lines?
4 Stars: 205 Votes
No, you must use the "Trim/Extend Multiple Elements" select the boundary then lines/walls...
Dimension witness line snaps??
Wed, Mar 28, 2012 at 1:12:09 PM
enlarge control dots on dimension witness line?
Fri, Apr 8, 2016 at 10:47:51 AM
KEYBOARD SHORTCUT FOR EDIT WITNESS LINES??
Fri, Dec 5, 2008 at 3:28:47 PM
exploding linked dimensions?
Wed, Apr 9, 2008 at 7:02:17 AM
Revit MEP 2012 - Linked Cad Lines being trimmed by Revit Plumbing Fixtures
Mon, Nov 7, 2011 at 12:54:25 PM
Page generation time: 1.3437
