Forums >> Revit Systems >> Technical Support >> view scale parameter
Wed, Jan 14, 2009 at 12:46:25 PM | view scale parameter
mitchelld
Is it possible to have a parameter in a family look at the view scale for part of a formula?  Here is an example of what I want to do.  The formula that I want is the "View Scale" x 3/16".  Obviously the view scale isn't accepted in the formula box.  Can this be done?  I want a reference line to move closer to the wall based on scale.  4 1/2" at 1/8", 2 1/4" at 1/4", etc.
Wed, Jan 14, 2009 at 1:01:58 PM | view scale parameter
No. Sorry but you can add a parameter that you fill in.
Thu, Jan 29, 2009 at 1:52:58 PM | view scale parameter
chuckbradley
Not that I know of, and believe me I tried.  I wanted it so I could use annotation for lights so they didn't resize with the scale.
I'm curious why you're wanting to use it.
Modify View Scale Parameter
Sat, Dec 3, 2011 at 8:51:44 AM
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:51 PM
Graphic Scale
Sat, Dec 3, 2011 at 9:08:24 AM
DWG import scale as parameter
Thu, Jun 27, 2019 at 10:03:48 AM
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
Page generation time: 1.9313
