Forums >> Revit Building >> Tips & Tricks >> Rendering image not showing
Wed, Jan 14, 2009 at 10:23:42 AM | Rendering image not showing
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
In my materials dialog, I assign a Acoustic Ceiling Tile bitmap to the material, but when I render it, it just shows a white luminous surface (I added a bit of illuminousity to it).  I thought that might be the problem, but I am also having the same problem with my sheet vinyl flooring bitmap not showing up.
Any ideas how to fix this?
Thanks,
Lorne
Denver, CO
Revit Architecture
Wed, Jan 14, 2009 at 10:41:04 AM | Rendering image not showing
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi lorne17, sorry for the question is only a doubt, but have you checked if your surfaces (ceiling and floor) have the materials that you created assinged with those bitmaps???, I mean is not only to create materials, you have to assign them to the components or surfaces, if not when you render, they will not appear in your image.
When Rendering, background image get realy bad
Sat, Nov 11, 2006 at 11:54:44 AM
REA 2009 Background Image when rendering
Mon, Nov 17, 2008 at 8:50:49 AM
Capture Rendering/Export Image
Wed, Aug 15, 2007 at 10:34:26 AM
Rendering with background image
Fri, Oct 1, 2010 at 11:09:57 AM
Revit File at 20% and it HASNT Started Rendering Yet?!?!
Sat, Apr 30, 2011 at 5:42:54 AM
Page generation time: 1.5570
