Forums >> Community >> The Studio >> PDF?
Tue, Jun 7, 2005 at 4:57:24 AM | PDF?
sdakota007
Is the ability to print to PDF gone in Revit 8???
Tue, Jun 7, 2005 at 10:42:51 AM | RE: PDF?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can still print to PDF, the Revit PDF printer is just no longer included in the install. It's available from the Autodesk Revit Download centre should you require it. HTH.
Mon, Jun 20, 2005 at 6:59:47 PM | RE: PDF?
DanielHurtubise
Unfortunately, it's not there anymore either.
Tue, Jun 21, 2005 at 6:34:00 AM | RE: PDF?
Chrisman
Apparently, due to technical complications, the 'Pine Bush' PDF writer is not being distributed with Revit Building 8. I suggest that you use 'Cute PDF' instead, and can be downloaded FOC from... http://www.acrosoftware.com/Products/CutePDF/writer.asp
Thu, Jul 21, 2005 at 10:10:33 PM | RE:
meelio
2 Stars: 3 Votes
I agree - in my opinion this is a superior (and free!) PDF driver, that works in all applications, not just Revit. I had all sorts of margin problems with the Pinebrush driver that dissappeared with CutePDF.
Fri, Jul 22, 2005 at 7:26:42 AM | RE: PDF?
3DLake
We use Adobe Acrobat Profession V 6.0. It just works! I hear the current V7.0 software works well also. It can create all the different sheet sizes and no one ever has a problem displaying or printing the PDF. It is “real Adobe” PDF after all. Sure it would be nice if Revit had a free tool for creating PDF but the same Acrobat tool works well with all my other software. It make PDF printing a non issue and one less thing to think about is a good thing.
Sun, Jul 24, 2005 at 4:25:37 AM | RE: PDF?
eldados
eldados Avatar
4.5 Stars: 8 Votes
I have to agree, Adobe 7 is just great! I never had to much fun with the Revit PDF writer, and I think it would be nice if Autodesk did some more work on it... will give cutePDf a go and see how it is though Winking
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
pdf print
Thu, Sep 25, 2014 at 6:04:04 PM
pdf
Sun, May 7, 2017 at 5:12:30 AM
11
Print to PDF
Fri, Jan 23, 2015 at 6:47:45 AM
Page generation time: 0.2720
