Forums >> Revit Building >> Technical Support >> Line where wall meets floor in 3d view
Wed, Jan 14, 2009 at 5:39:50 AM | Line where wall meets floor in 3d view
RNLRNL
I have a milti-stotey building and to simplify things the I have extended the structural walls to pass through several storys. This is fine however in 3d view there is no line showing where the wall emerges from one floor to the next. Does anyone have a solution for how to make this join line appear.
Attached is a word document with an image of the view I am referring to.
Wed, Jan 14, 2009 at 5:48:48 AM | Line where wall meets floor in 3d view
4 Stars: 205 Votes
Hi, use the "Join Geometry" with walls and floors...
Wed, Jan 14, 2009 at 5:58:18 AM | Line where wall meets floor in 3d view
RNLRNL
Thanks , taht worked perfectly. Do you have any suggestions when the wall passes through a ramp as the join geometry function doesn't work.
Model line types not showing correctly in one floor plan
Wed, Jun 22, 2011 at 11:20:28 AM
curtain wall cuts when close to floor line
Thu, Aug 27, 2015 at 4:48:48 PM
wall meeting topography question
Wed, Feb 3, 2010 at 12:18:44 PM
Horizontal Wall or Wrapping Floor
Mon, Jan 21, 2008 at 3:40:31 PM
wall/floor - in section view
Thu, Oct 27, 2005 at 2:58:13 AM
Page generation time: 1.1986
