Forums >> Revit Building >> Technical Support >> Roof Question
Tue, Jan 13, 2009 at 3:35:15 PM | Roof Question
Suzque
I have a tri-level residence and the roof bears on the main floor for the front elevation and on the upper level for the rear elevation.  How do I change the different heights to creat a "hockey stick" roof?  I currently have drawn the roof using Roof by Footprint.  thanks for the help!
Tue, Jan 13, 2009 at 3:44:03 PM | Roof Question
Suzque
Found my answer...
Wed, Jan 14, 2009 at 8:34:40 AM | Roof Question
coreed
coreed Avatar
4 Stars: 16 Votes
we try to encourage users once they find the solution to their own question, that they post that solution also as it may help someone else with the same problem.
best regards,
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 14, 2009 at 8:59:38 AM | Roof Question
Suzque
Sorry...  here's where I found my answer.  From the post "multi-level roof question: need help"
1-   create roof picking walls as all edges are attached to upper level
2-    select the roof and go to edit
3-    select edge which should be lower, go to the properties and  secify "offset from roof base"
as required, should be the diffrence between first flor plate and second floor plate
(negative number)
Extruded roof - fascia - (Newbie question)
Wed, Jul 5, 2017 at 8:12:43 PM
13
Roof Question
Wed, Sep 20, 2017 at 10:13:43 AM
Revit 2013 Roof Question
Fri, Jul 13, 2012 at 7:43:31 PM
Roof question
Mon, Apr 28, 2008 at 1:30:48 PM
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:50 AM
Page generation time: 0.3558
