Forums >> Revit Structure >> Technical Support >> Make an Architectural View show up in a section on a structural plan
Tue, Jan 13, 2009 at 11:05:30 AM | Make an Architectural View show up in a section on a structural plan
benson1321
I have a structural steel layout for a project and I'm trying to make one of the sections on that plan show an Architectural View when clicked on. Any help is greatly appreciated.
Fri, Jan 16, 2009 at 3:46:15 PM | Make an Architectural View show up in a section on a structural plan
emgeeo
3.5 Stars: 7 Votes
In the view you would like to display the architectural elevation in...
1.  Go to your Visibility/Graphics overides.
2.  Under the 'Revit Links' tab select the 'By Host View' button next to the linked Revit file you'd like to pull your Arch elevation from.
3.  Once in the RVT Link Display Settings dialogue select the 'Custom' button.  Next to the Linked View pulldown, select the name of the Arch Elevation you would like to use.
Let me know if that doesn't work/makes sense.  Or, let me know if it does work.
Mon, Jan 19, 2009 at 8:37:21 AM | Make an Architectural View show up in a section on a structural plan
benson1321
It did something and it looks good. Thank you for your help.
Section view problem
Fri, Nov 14, 2008 at 10:10:50 AM
visibility of reinforcing from linked structural model in architectural sections
Thu, May 29, 2008 at 3:44:37 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Architectural Vs. Structural Linking
Tue, Feb 19, 2019 at 10:42:28 PM
ARCHITECTURAL COLUMNS
Sun, Feb 12, 2006 at 9:52:27 AM
Page generation time: 1.1757
