14 Users Online (12 Members):
Forums >> General Discussion >> Wishlist >> Quit Deselecting My Selection!
9 Posts No Rating |
When I cancel a command, it does not mean I want to deselect the set that i spent 5 minutes making. Either (pleeease) add the ability to enter selection sets into memory (a'la Photoshop) or simply have a two level (optional) cancel, once for the command and once more for the selection set. Thanks.
9 Posts No Rating |
Right click in the view and choose "Select Previous"?
9 Posts No Rating |
If I select a set of objects to move, then accidentally click the Copy Command Button instead, hitting escape drops my selection, and select previous only works with objects that have had a command completed with them. I appreciate the suggestion, though. Thanks.
9 Posts No Rating |
You're right, it doesn't really help. What's weird though is that if you select an object and then just click somewhere else to deselect it, "Select Previous" works as it should even though select/deselect is not really a command. Erratic behaviour, to say the least.
selection issue |
Fri, Mar 4, 2005 at 3:43:11 PM
selection filter |
Sun, May 21, 2006 at 9:32:56 PM
Tag all not tagged by selection help |
Fri, Feb 17, 2012 at 1:28:08 PM
Rule-Based Filter SELECTION |
Sun, Dec 9, 2018 at 6:56:29 AM
polyline selection window |
Sat, Feb 6, 2016 at 7:57:07 AM
