13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Hatch pattern
4 Posts No Rating |
My custom stone hatch pattern won't scale. Is this normal and can be fixed or is something wrong with my hatch?
4 Posts No Rating |
Meaning it won't scale correctly when I change the scale of my view from 1/4"=1'-0" to 1/2"=1'-0"
You have a drafting pattern which is set to be a certain size on the sheet regardless of the scale. You need to go into your pattern file and change it to a model pattern.
4 Posts No Rating |
Thanks Tim123! I was also having trouble importing my pat file because it said that "no model type patterns found." I found another thread that said you just need to add ;%TYPE=MODEL to your pat file, in case anyone else was having that problem.
Exporting hatch pattern |
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing |
Mon, May 8, 2017 at 12:56:51 PM
Hatch 22- Curve Pattern |
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor |
Wed, Jan 28, 2015 at 8:46:58 PM
Fill Pattern/Hatch Pattern are not coherent in different views |
Thu, Feb 16, 2012 at 7:20:52 AM
