Forums >> Revit Building >> Technical Support >> Keynotes Filter By Sheet Not Working
Tue, Jan 13, 2009 at 8:59:16 AM | Keynotes Filter By Sheet Not Working
Jmarchese
We are having a problem with Keynotes filtering by sheet.  When we pull the keynote schedule onto a sheet and select "Filter By Sheet", some of the keynotes are missing.  I haven't been able to find a pattern in why they aren't filtering properly, and when I uncheck it, all of the keynotes appear.  What settings should I check to resolve this?  I've attached a screenshot to illustrate the issue.
Thanks,
Jim
Tue, Jan 13, 2009 at 9:38:42 AM | Keynotes Filter By Sheet Not Working
Jmarchese
Sorry.  I've attached it now.  Thanks!
Tue, Jan 13, 2009 at 10:23:27 AM | Keynotes Filter By Sheet Not Working
In your keynote schedule did you also check the box in the filter tab to filter by sheet?  If not, the schedule will show the keynote index used on oter sheets but not the value.
Tue, Jan 13, 2009 at 10:55:17 AM | Keynotes Filter By Sheet Not Working
Jmarchese
yes, the button is checked.
Tue, Jan 13, 2009 at 2:02:29 PM | Keynotes Filter By Sheet Not Working
Sorry ... looks like you are not telling us everything.  I have not had the keynote feature fail.
Tue, Jan 13, 2009 at 2:31:49 PM | Keynotes Filter By Sheet Not Working
Jmarchese
The problem was that the Keynotes were a hair outside the Annotation Crop line.  Thanks for looking into this!
Wed, Aug 25, 2010 at 12:47:35 PM | Keynotes Filter By Sheet Not Working
cdellinger
Thank you for posting your solution. curse annotation crop.
Keynotes "Filter by Sheet" not working
Tue, Mar 6, 2018 at 2:26:09 PM
Keynotes filter by sheet and default graphics
Mon, Jan 8, 2018 at 3:40:58 PM
Revit 2015 - Filter Note Block Keynotes by Those Visible on a Sheet
Sun, Mar 4, 2018 at 2:08:58 PM
Note Block Filter
Fri, Sep 18, 2009 at 1:15:29 PM
Keynotes (CSI) and General Notes - combining on one sheet
Mon, Jan 24, 2011 at 12:29:35 PM
Page generation time: 0.4316
