Forums >> Revit Building >> Technical Support >> How to create an irregular shape mass
Mon, Jan 12, 2009 at 10:39:18 PM | How to create an irregular shape mass
sigma
I have been trying to create a mass which is somewhat like the attached image. This will be a part of a ceiling. If someone can suggest me that will be great. Thanks in advance.
Sigma
Tue, Jan 13, 2009 at 4:38:25 AM | How to create an irregular shape mass
tim123
4 Stars: 19 Votes
You can extrude this or create it with a sweep.
Tue, Jan 13, 2009 at 8:40:59 AM | tim123
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting tim123 from 2009-01-13 04:38:25
"You can extrude this or create it with a sweep."
Ditto!!
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jan 13, 2009 at 4:47:17 PM | How to create an irregular shape mass
IloveSKETCHUP
creating a new mass is easier than having to match a profile that exist.
if the profile exist and its a cieling, you will have to go in section perp to that profile, create a mass using the reference plane that is par and then extrude it as deep as you need to. you can adjust with the arrows once it is created.
Tue, Jan 13, 2009 at 5:32:16 PM | How to create an irregular shape mass
sigma
Thanks to you all. I have created a new mass profile and could not see it because my show mass button was not turned on. I was not doing revit for a while and I have forgotten few tricks! It's good as we are helping each other through this platform and I am glad to be part of it. I just love REVIT......
Sigma
Tue, Jan 13, 2009 at 5:37:28 PM | How to create an irregular shape mass
IloveSKETCHUP
and iLOVEsketchup. i'm just being forced to use this god forsaken program.
Tue, Jan 13, 2009 at 6:43:37 PM | How to create an irregular shape mass
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Does somebody have a gun to your head?
Fri, Jan 16, 2009 at 12:01:39 AM | How to create an irregular shape mass
sigma
I am in trouble. This mass is transparent. I tried to change the material in the "property element" but it is not changing!
Folks, do you know how to do it?  I need to give it a solid colour finish.
Sigma
Fri, Jan 16, 2009 at 3:38:11 AM | How to create an irregular shape mass
goodnightren
First, you need  to check the mass subcategory in the mass property, then go to the object style in the setting and change the right mass subcategory's material. Then click OK.
I think it works. You can try.
Fri, Jan 16, 2009 at 4:32:57 AM | How to create an irregular shape mass
tim123
4 Stars: 19 Votes
As goodnightren says you can change this in the settings.  It would have been better to create this in the ceiling category rather than as a mass.
How would I create this as a mass or componant
Wed, Aug 5, 2009 at 4:09:43 PM
Curving a Truss around an irregular mass
Sun, Mar 1, 2009 at 8:19:44 AM
Double ellipse mass
Wed, Nov 5, 2008 at 1:59:06 AM
Revit command similar to EDGESURF in Autocad? for irregular shape 3d massing
Mon, Feb 1, 2016 at 8:34:08 AM
Irregular (on plan) shaped walls
Thu, Nov 23, 2006 at 3:28:47 AM
Page generation time: 4.7386
