Forums >> Revit Building >> Technical Support >> How/When do I use each Parameter?
Mon, Jan 12, 2009 at 4:56:57 PM | How/When do I use each Parameter?
JessicaPetty
When should I use each type of parameter (number vs integer..etc?)
 How do I write the formulas for each type of parameter?
 Thanks So Much!
Mon, Jan 12, 2009 at 5:50:21 PM | How/When do I use each Parameter?
Check out your help menu - it will answer these questions.
Mon, Jan 12, 2009 at 6:08:38 PM | How/When do I use each Parameter?
JessicaPetty
Thanks...but it has been no help.  Here is my current delima, but Im not sure if I am going about it correctly & I feel I would better understand if I understood all the parameters better:
I need to create some sort of parameter for my Material Takeoff Schedule - I want to be able to show how many studs I will be using.  My studs are all 16" OC, so I created a "Calculated Value" titled Stud Count.  It is an Integer type & The formula is "Length/16"Winking
It works perfectly - except that it does this for ALL materials, I want to limit it to just clculating the value for materials that have "stud" in the name.  I feel like I should do this with a yes/no parameter, but Im not sure & I cannot seem to get this to work.  Thanks!
Mon, Jan 12, 2009 at 6:22:55 PM | How/When do I use each Parameter?
First, HELP answers your first questions.  It explains interger, number and it tells you how to write formulas.
Second - Help will also help you with your new question.  Look in help for schedules and then look at filters.  This is just logic.  If you want to calculate only walls that have stud in their name, then you have to limit your schedule to those walls.
Tue, Jan 13, 2009 at 11:02:19 AM | How/When do I use each Parameter?
JessicaPetty
Im still lost...thanks tho
Tue, Jan 20, 2009 at 6:50:11 PM | How/When do I use each Parameter?
TCatana
wwhub - The help files in Revit are terrible and convoluted.  The program does a lot more than what is explained in the help files.  For the most part the help files treat you like you are stupid and answer dumb or obvious questions.  What she is looking for is not in the help files.  Convoluted pieces of what she wants to do are.  A simple example would have been more helpful.
Jessica - What I think WWhub is alluding to, is that you can filter by that wall type, then it will only give you your count on that wall type.  I don't know if that will help - if you are also using the schedule for other wall types.
Wed, Jan 21, 2009 at 10:21:02 AM | How/When do I use each Parameter?
JessicaPetty
Thank you TC - that is EXACTLY how I feel about "help"
I was able to play around with the parameters a bit & filters.  Its OK for now, I just know its capable of so much more!
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Add angle parameter to generic annotation with offset parameter
Mon, Mar 2, 2020 at 12:57:06 AM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
NOT Parameter Formula Question
Fri, Apr 10, 2009 at 8:30:17 AM
Page generation time: 0.4449
