Forums >> Revit Building >> Technical Support >> Help Rescaling a custom family
Mon, Jun 6, 2005 at 1:27:24 PM | Help Rescaling a custom family
XxLarry007xX
i recently made a custom counter and oven unit as a new family. When I try to load it as a component in another project, it is at a larger scale. How do I change the scale of the object so that it matches the rest of the project? thanks for your help.
Tue, Jun 7, 2005 at 12:36:37 AM | RE: Help Rescaling a custom family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What type of family is it. When you model something in revit it is always drawn 1:1 and scales according to each view. If its 2D then you may have used a symbol as opposed to a detail component. A symbol always has the same print scale regardless of the view scale. Anyway, if it is modelled and you need to change the size, open the family and use the scale tool on each of the elements. Alternatively make the unit parametric then simply set the size as you require. HTH.
Mon, Aug 22, 2011 at 9:59:33 AM | Help Rescaling a custom family
Lochnesska
Lochnesska Avatar
To Mr. Spot: how do I make the unit parametric? I have a symbol in 2D and I want to use it in different scales but I don't know how to do it.
 Thank you for your help.
Nessie
Revit 2013
Rendering problem with Custon Family
Tue, Mar 11, 2008 at 6:49:58 AM
Preblems with custom families
Thu, Sep 17, 2009 at 8:08:26 AM
Annotations and fill patterns not automatically resizing when rescaling views
Wed, May 30, 2007 at 4:19:51 PM
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:12 PM
Custom Linetype Not Showing When Inside of Another Family?
Mon, Jan 25, 2016 at 9:11:55 AM
Page generation time: 0.7153
