Forums >> Revit Building >> Technical Support >> Rendering Elevation 3d views with scale
Mon, Jan 12, 2009 at 11:31:15 AM | Rendering Elevation 3d views with scale
insid
I'm trying to render the four elevations of a project that I'm working on.  The problem I'm finding is that, due to my topography layout, the topography is longer east/west than it is north/south.  When I change the orientation of the 3d view, I need to zoom into the building to bring it to the scale that I wish to have it, yet I am unable to make the building the same size throughout all views.
Is there any way to force the scale on screen/in render to be the same on all four elevations?  I am unable to get the building to have the same scale in each of the four rendered views.
 Thanks for any advice that may be given!
50873_east-view.jpg50873_east-view-zoomed.jpg50873_north-view.jpg50873_north-view-zoomed.jpg
Mon, Jan 12, 2009 at 11:39:07 AM | Rendering Elevation 3d views with scale
tim123
4 Stars: 19 Votes
Are you sure that it is not just the zoom factor?  Drag the views onto a sheet and check.  The view scale should determine the scale.
Mon, Jan 12, 2009 at 11:44:31 AM | Rendering Elevation 3d views with scale
insid
Essentially, I have to zoom into the view that's given, and I don't know of any way, other than with the scroll wheel to bring the building into 'focus' so to speak.  If I can create a specific zoom factor with a command that I am unaware of, then that would solve my problem.  The views are set to 1/8"=1'.. Are you suggesting that I change the scale factor there, and it would automatically increase the size of the building and prevent any change between views?
Mon, Jan 12, 2009 at 11:54:07 AM | Rendering Elevation 3d views with scale
tim123
4 Stars: 19 Votes
Revit does not work with zoom factors like AutoCAD, but uses the scale to determine the size of the drawing on the sheet.  If you change the scale on all your views (or create a view template) they should all be the same size (scale) on your sheet.
Sat, Jan 17, 2009 at 1:33:46 PM | Rendering Elevation 3d views with scale
71veedub
can anyone post rederd elevation with scale?
Sat, Jan 17, 2009 at 7:18:02 PM | Rendering Elevation 3d views with scale
4 Stars: 205 Votes
I anwser this question in the other post...
Tue, Aug 14, 2012 at 9:43:43 AM | Rendering Elevation 3d views with scale
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
And where is that other post Typhoon?
Building Elevation Scale
Fri, Apr 19, 2013 at 9:24:42 AM
scale bar for elevations and sections
Fri, Jun 22, 2012 at 8:15:58 PM
Printing views to scale?
Fri, Aug 31, 2007 at 8:33:25 AM
Changing the scale of a Bump image for rendering
Mon, Sep 26, 2016 at 1:03:41 PM
any work around for this? transparent glass in shaded elevation views, revit 201
Mon, Jan 28, 2013 at 11:19:53 PM
Page generation time: 0.8566
