Forums >> Revit Building >> Technical Support >> Central-file sharing over the net?
Mon, Jan 12, 2009 at 10:12:53 AM | Central-file sharing over the net?
Fryingpanwarrior
Fryingpanwarrior Avatar
Hi all,
I'm situated in Durban (SA) and starting a project in collaboration with another architectural practice in Johannesburg, 600 kms away. We hope to be working on the same project (central file) in tandem, and this poses one or two major problems...
Is it possible for two or more users to access the same file remotely, and work on it at the same time via the net, as we would normally do in an office via a network? Is third-party software needed to make this happen? Anyone experienced in doing so?
Thanks!
Mon, Jan 12, 2009 at 5:07:43 PM | Central-file sharing over the net?
Do you have a T1 between your offices?  I doubt it ... therefore the answer is you are in trouble.
You need to check into all the posts here and on AUGI as well as reading your help file on working remotely.
Tue, Jan 13, 2009 at 4:42:01 PM | Central-file sharing over the net?
IloveSKETCHUP
We use a vpn - it takes a while to open as this is not the location of the network, but once we do we save to desktop and then save to central as usual when done. seems to work well.
 using cisco vpn client
Wed, Jan 14, 2009 at 12:18:38 AM | Central-file sharing over the net?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm yet to hear of anyone who successfully gets a save over the net to work... It is painfully slow no matter how fast your connection...
I recommend the VPN method.  The only issue is it requires vacant computers at the server end for people to connect to and work on...
Regards,
Chris.
Wed, Jan 14, 2009 at 5:22:34 AM | Central-file sharing over the net?
Fryingpanwarrior
Thanks all,
Those options are definitely worth a look at.
FPW.
Sex, Drugs, and Revit...
SHARING A CENTRAL FILE
Wed, Feb 20, 2008 at 1:08:49 PM
Central File Access From Multiple Offices
Wed, Aug 20, 2014 at 10:01:50 AM
project sharing
Tue, Jun 21, 2011 at 3:26:57 PM
sharing a model with another firm over FTP?
Thu, Feb 19, 2009 at 12:50:56 PM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
Page generation time: 0.4979
