Forums >> Revit Building >> Technical Support >> ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 2:15:16 AM | ACAD Import Problems (With Blocks)
ScopeDrafting
Have problems with importing ACAD dwgs into RAC 2009 which have blocks in them. The blocks and occasionaly polylines do not import. I can work around it by going into the drawing and exploding the offending objects but that requires importing it, checking that everything came though then fixing it and importing it again. Is there an easier solution? WHat am I missing?Thanks.
Mon, Jan 12, 2009 at 5:26:46 AM | ACAD Import Problems (With Blocks)
4 Stars: 205 Votes
If you have your drawing by layers when you import, in the dialog box, you can select what layers you want import (and not) to the Revit project, my advise is before you import take a look to your DWG file and explode all blocks, hatch, text...
line weights problems corresponding to ACAD ref files
Tue, May 4, 2010 at 8:37:29 AM
Exported file to ACAD has problems with custom PATTERNS [made in acad]
Mon, Jun 23, 2008 at 3:21:32 PM
Importing SHX font from ACAD into Revit
Wed, Oct 18, 2006 at 9:24:53 AM
ACAD Import
Wed, Apr 1, 2009 at 9:04:59 PM
How to import 3D CAD blocks into Revit?
Thu, Jul 22, 2010 at 12:52:10 PM
Page generation time: 0.8210
